fuel leak on my 1945 D4
D Brown Utah
10-03-2006 12:01:49
I have a fuel leak coming from between the injector pump and the block. the leak is not spraying fuel just running down the block and pump. what is there behind there that could be leaking. may be the same problem after I shut it down and let it set a couple of days the fuel filter is empty. what could be leaking I cant see behind it. the sn is 2T5845
thank you
D Brown Utah
10-03-2006 19:04:22
 Re: fuel leak on my 1945 D4 in reply to D Brown Utah, 10-03-2006 12:01:49
I found the leak it coming from a line that opens under the pump. the line T's into the bottom of the pump and goes up to the injector bleed off line I think. question is why is the line open at the bottom? where it goes to the injector bleed off line what keeps it from leaking fuel on to the groung all the time. do I have an injector leaking too much or what? the line clamped to the block under the pump and is open under the clamp. what would happen if I run the line back to the top of the fuel pump like other diesel motors also it is hard to start when it is cold.
thank You
hectorgemme
10-03-2006 13:36:13
check the tube fitting back the fuel pump.
