case 450b angle cylinder
roney.mcstotts
10-06-2006 03:01:26
I am trying to get the bolt off the bottom of the angle cylinder rod to replace the seals in the hydraulic cylinder can't get it to budge. any susjestions I haven't tried to heat it yet.I have had stuff that had to be heated to melt the lock tight to remove the fastner. will this hurt the rod
Case450
10-10-2006 17:58:49
 Re: case 450b angle cylinder in reply to roney.mcstotts, 10-06-2006 03:01:26
i wouldnt think it would hurt the rod....you must have at least a one inch thick cylinder rod...you could try and keep it cool with wet rags while your heating to help keep the metal cool. I'm not a mechanic or anything. Just my two cents. Good luck.
