HD6 injection pump
naz
10-06-2006 15:43:26
Hi all,could someone tell me if there is a filter or screen on injection pump in the hd6(1960)Thought it might be dirty and starving for fuel.It will start and run for a few seconds then quite.If I try to start again it won't start.When I let it sit for a few minutes it will run again(4-5 seconds).Not getting enough fuel....New filters in it....Was working fine before the water in the fuel.
Thanks for any help,
Naz
TimBinWV
11-19-2006 18:12:24
 Re: HD6 injection pump in reply to naz, 10-06-2006 15:43:26
Hey,Naz...I always take line off the injectors one at a time,turning the engine over til I get a good shot of fuel out that line before tightening it and going to the next, One trip through usually does it. Good luck,either way...
EBEN
10-11-2006 03:58:32
I seem to remember something about a check or pressure relief valve on the PSB4-90EH pump I have a PSB book at the shop. When I run out there on Thursday AM I will check it and let you know. The valve I speak of is at the forward of the injection head, it is there to maintain 5-15 psi on the pump I think. Eb
EBEN
10-09-2006 04:15:05
I had trouble just like you describe. The pressure line that feeds the injection pump had deteriorated inside and if I cranked the machine, fuel would flow. Once I reconnected the hose the engine would fire then starve for fuel. I had everything loose, blew through the lines, pumped the fuel tank dry and inspected, everything. I replaced all of the fuel hoses shortly after I removed all of my hair. All is well, Allis runs fine! Hope this helps. Eb
naz??
10-09-2006 12:10:59
 Re: HD6 injection pump in reply to EBEN, 10-09-2006 04:15:05
Thanks Eben,will look into that. I have fuel up to filters full flow and opened lines into engine,have fuel coming out there(maybe not enough)It wants to run,I don't want to run batteries down again,just charged them up the other day.Thanks again for reply,
Naz
hectorgemme
10-06-2006 18:15:39
the hd6 fuel pump dont have fiter or screen on just loose the small cap screw on the 2 fuel filter housing and when the fuel comming out just tight the capscrew and he should start.
naz
10-07-2006 02:56:34
 Re: HD6 injection pump in reply to hectorgemme, 10-06-2006 18:15:39
Thanks Hector,will try her again today.Filters were full of fuel,bled the lines into cylinders,maybe still some air in there.
Naz
naz
10-07-2006 11:03:52
 Re: HD6 injection pump in reply to naz, 10-07-2006 02:56:34
Tried it again and it started like before4-5 seconds then quite.Tried again and it wants to start but just won't pick it up.Smoke comming out of exhaust,
Appreciate any thoughts,
Naz
hectorgemme
10-08-2006 02:18:55
 Re: HD6 injection pump in reply to naz, 10-07-2006 11:03:52
HI I suspect missing fuel you should disconnect the fuel line inter the fuel filter and you should see if the fuel is comming full pipe maybe the valve on bottom tank is not full open ,sorry for my bad english writting.
naz
10-08-2006 04:42:59
 Re: HD6 injection pump in reply to hectorgemme, 10-08-2006 02:18:55
Thanks again for reply Hector.Fuel shutoff from tank is open,fuel flows out of bleeder screw on filters.I suspect the lines are full flow into filters,will check them out again,
Naz
hectorgemme
10-08-2006 07:30:40
 Re: HD6 injection pump in reply to naz, 10-08-2006 04:42:59
HI A couple year it apen to me the same probleme and found in the fuel tank a rubber patch was blocking the hole just make sure disconnect the pipe from the tank and open the valve and you will be sure if the fuel tank
hole is not block . good luck
hector
