350B backhoe
Steve B
11-27-2001 19:00:33
Can anyone tell me if the 9300 series backhoe will fit a 350B dozer? The person has all the brackets ect.The manual shows this hoe on a 350B, But the guy says he's never seen one on a 350... Thanks steve
Jim
12-18-2001 22:38:03
 Re: 350B backhoe in reply to Steve B, 11-27-2001 19:00:33
I have a Model #50 hoe I can make you a deal on, could use some hoses but I have rebuilt and used it approx 250 hrs this summer I have a 440 and have found it to be dangerious in extreame terain and would like to part with it. can send pictures.
Roland
11-28-2001 13:42:59
The 9300 backhoe is to heavy to keep on the 350 tracter all the time, very hard on the under carriage. Good thing is it is a detachable backhoe, 5 minutes ,ten on a bad day to attach or remove. Goes on the same mount as the ripper. You will also need the larger pump or it will be kind of slow.
pecord
11-27-2001 19:53:13
steve yes they were on a 350, the one that you saw at our place was on a 350 and that is a 9300- rich
bcPA
11-30-2001 11:17:50
 Re: Re: 350B backhoe in reply to pecord, 11-27-2001 19:53:13
From what I have been told, a 9350 hoe and a model 50 hoe are the correct size for a three fifty jd. The 9300 will make the machine run on its rear heels and the front will want to pull a wheelie. You can fill the ft bucket with dirt for weight but I believe that will acclerate undercarriage wear. If you already have a 9300 hoe thats one thing but I wouldnt go out and buy trouble.
Steve B
11-28-2001 07:16:05
Hi Rich,
Hows it going? I think all I will need is some different lift arms. I have a dozer. My lift arms taper down, and I think the hoe requires the straight arms so the assembly can attach to them???
