JD 450 HLR Oil Pressure Test Port
Phil - MO
10-07-2006 05:31:36
I have a straight JD 450 Loader (I think).
I asked the JD dealer where the test port for the HLR hydraulic testing is located and he said under the bung hole he thought. I'm 100 miles away so can't look at it and will be working on it Monday. Where is the test port located and is it 1/8" pipe thread?
Don K.
10-07-2006 05:43:58
 Re: JD 450 HLR Oil Pressure Test Port in reply to Phil - MO, 10-07-2006 05:31:36
Yes it is under the bung hole and it is 1/8" pipe. Take out the plug with an allen wrench. Put a little grease on the end of the allen wrench so you don't drop the plug.
Phil - MO
10-07-2006 06:06:20
 Re: JD 450 HLR Oil Pressure Test Port in reply to Don K., 10-07-2006 05:43:58
Thanks for the quick response.
One other question -- I thought it was a straight JD 450 loader with serial number plate missing. I have found paper work with 1970 model 450 serial number 111869 written on it. Another piece of paper with serial number 101000.
Us it possible to distinguish between model 450 and model 450B etc.?
