HLR and clutch JD 450
Phil - MO
10-08-2006 05:19:40
Roy Suomi -- I was looking over your past posts and you mentioned to somebody working on a 450C that if the clutch pedal adjustment free play (3 3/4") is made and the adjustment bolt raises as you turn it out the linkage is rusted stuck.
Mine does this and I just thought the return spring was broken maybe? This might be my slipping problem!!
A new clutch was installed 200 hours ago when the engine was rebuilt.
I'll be working on the machine Monday.
Anybody familiar with this problem:
WHERE does the clutch linkage usually rust up or bind and how did you free it???
RoY Suomi
10-08-2006 06:54:55
 Re: HLR and clutch JD 450 in reply to Phil - MO, 10-08-2006 05:19:40
Early machines had greasable throw-out bearings, not later models..Not sure of serial number break for this..
Phil - MO
10-08-2006 05:23:15
Also can't seem to find the grease fitting for the throughout bearing??
John Wood
10-08-2006 06:33:35
 Re: HLR and clutch JD 450 in reply to Phil - MO, 10-08-2006 05:23:15
On my machine, the grease fitting is on the top of the bell housing at the front center, right by the top edge of the floor plates. Mine is a 90 degree grease fitting.
HTH
J.
