Hough 65C loader steering oil
Monte Neff
10-10-2006 11:29:06
Hi all. Just found this forum. I hope you can help. I am working on a 65C loader that has slow bucket hydraulics. I had the Vickers pump rebuilt. It was totally shot. The hoist still functions real slow. Looking at the hoses shows the front pump section going to a valve on the right side of the frame. I think it is a priority valve for the steering then tees into the hoist line off the back section of the pump when steering is not needed. I am thinking the priority valve is not sending oil to the hoist at all. I noticed a cap visible through a hole in the frame and removed the cap. There is an adjustment like a relief valve. It was screwed all the way in. I unscrewed it about 20 turns to see if it would give me more oil to the hoist. Didn't do any good. It looks like the adjustment goes into a plug that can be unscrewed from the valve body. I am thinking that pump debris from it's failure has "stuck" the priority valve. Am I correct in my thinking? Can I pull the cap and remove what ever is inside to clean it out? I am guess I will have to drain the oil tank and still have a lot of oil coming out. Correct?
Thanks
Monte
finlay cocks
01-10-2007 19:34:14
 Re: Hough 65C loader steering oil in reply to Monte Neff, 10-10-2006 11:29:06
Have you checked for clogged filters?does the steering work?how is the intake pipe to the pump?is the relief valve stuck open?condition of control valve unit?You will find the problem in the pressure side,as no pressure is being metered.
