Trouble pulling reverser from trans
sminnick
10-13-2006 06:10:39
I hope someone can help here. We have been trying to work on a leak between the reverser and trans on a JD 350C loader. We pulled the engine and removed all the the bolts according to the service manual, but the dang thing will not budge. It is supposed to slide up and off the studs from the trans, but we can not get it to move. We have put and jack under in and we have tried to pull it from the top.. no luck. Any ideas. Could there be a bolt going through from the inside of the trans? Like I said any help would be appreciated.
sminnick
10-14-2006 02:06:49
 Re: Trouble pulling reverser from trans in reply to sminnick, 10-13-2006 06:10:39
I have some kids working on it at a local tech school. I will scheck to see that the bolts under the clutch housing are out. Thanks. They are afraid to beat on it too hard.
Roy Suomi
10-13-2006 13:43:44
I've seen the splines in the coupler rusted together..Keep working it and spray a good quality pennetrating oil into the split..Sometimes the dowels seize up too..You might have to man handle it..Don't be bashful , those castings are pretty thick..I've used a spud bar and a sledge hammer to coax them apart.. Did you take out the " clutch housing "bolts that go up from below around the front crossbar???
Jonathan in MA
10-13-2006 11:41:11
Its got dowel pins around the bolts also...so that may be giving you some trouble... should only be the 4 bolts/studs on the end and the ones going through the side-frames into the case..
