Remove right side streering clutch IH TD6 crawler
Gadi Silberstei
10-14-2006 12:48:33
I opened the top cover of the rear transmision.I removed the breaks.What more I have to disassemble to remove the streering clutch ?.
hectorgemme
10-14-2006 14:40:17
 Re: Remove right side streering clutch IH TD6 cra in reply to Gadi Silberstein, 10-14-2006 12:48:33
HI You have to removed the release fork stering cluch and loose the adjuster drive bevel gear bearing and take off the 6 luck bolt being the adjuster bearing and push the coupling on stering cluch side after removed the bolt from the stering drum to the flange pinion sproket drive.
