JoelD
10-15-2006 19:48:38
Re: another 350 reverser in reply to Pilgrim, 10-15-2006 05:21:22
Hi, as you can see from my posts, I'm dealing with a similar problem, only in reverse, and I can clearly see it's the preasure is low, therefore, probably a leak in my reverser pack, maybe a piston? I would think, if you are holding preasure and slipping, and only in reverse, sounds like the reverser clutch pack is slipping. For me, it was easy to rule out the stearing clutches as the tracks spun in forward when I hit something, until the oil got warm and then leaked down. Probably not the best test, but to confirm it's not the stearing clutches, put the reverser in reverse and the tranny in reverse, thus you'll be going forward, I bet it will spin the tracks, if so, it's probably definately the reverser pack. Could not see, based on diagrams, how you could have preasure in system and not in pack?? I guess there may be some scenerio?? You've gotten a response from one of the most experienced guys. Search for the responses from the other.
