I had posted this to the JD forum here, but after reading this forum I felt it was a better place for help.I replaced the diff housing on a JD410 backhoe. The backhoe itself came off in this process (long story). Either way I get her running and hydraulics are good for like 20 minutes then a hose blows. Replace the hose and now no hydraulics. What I have done so far. Cleaned : Hydro filter pressure release. Tranny pressure release. Hyrdo pressure release. Pump filter screen Tranny screen. Funny thing is I can add shims to the pressure release (takes a lot) to get it to 1000 psi. With the shims that were in there before it was at 500PSI. I cannot get anymore shims in there to go higher then 1000psi. And not much more movement at 1000psi. Backhoe pads can go up and down but slow They can lift the machine. Tilt on loader works OK but slow. Boom on loader hardly moves. Pump is about 2 years old and not many hours on it. Hose blew when I had the backhoe off and the lines plugged. I have since been able to get backhoe attached. I assume I got the two hoses that attach to the backhoe correctly as the controls move in the correct direction. Other then that I am at a loss and have spent more time chasing this hydro problem then replacing the rearend. Frustrating as the hydraulics worked fine before the hose blew. Any other ideas before I bury this thing? :) Is it possible that there is some type of airlock in the system? I mean it ran fine before I replaced the hose. I know the system will purge the air out it self..... ...but. Thanks in advance, Chris
