AC 655 Brake Band Removal
roadstar
10-23-2006 15:49:03
How do I remove the brake bands from my 655 Loader? Do I have to pull the clutch assembly? Does anyone know where I can get the new bands?
Any info is much appreciated.
indiana allis
10-25-2006 15:09:49
 Re: AC 655 Brake Band Removal in reply to roadstar, 10-23-2006 15:49:03
If you have the part number, a good source for parts is minnpar. You can look up price and available stock at minnpar.com or e-mail info@minnpar.com.
jdemaris@usadatanet.net
10-23-2006 17:18:31
You can buy new bands from a dealer. Most ex-industrial Allis Chalmers dealers still get the parts - mostly from AGCO. In regard to removal - if the bands are one-piece - then the clutch-drums must come out with the bands on them. I've seen some though that have take-apart bands that come in two halves and link at the bottom under the clutch-drum. They come out without pulling the drum.
MICHAEL B SMITH
10-24-2006 14:49:03
 Re: AC 655 Brake Band Removal in reply to jdemaris@usadatanet.net, 10-23-2006 17:18:31
WHAT WILL IT TAKE TO GET THE DRUM OUT
jdemaris
10-25-2006 06:14:15
 Re: AC 655 Brake Band Removal in reply to MICHAEL B SMITH, 10-24-2006 14:49:03
Take the top-cover off. Unhook the linkage, unbolt the clutch-assembly where it is connected to the final-drive input flange (on the outside) - and - on the inside - take the lock-ring off the splined shaft and push that shaft into (towards) the ring-gear carrier until it is totally out of the clutch pack. Then, just lift out.
