D6 Dozer VS. Fiat HD-11
H2
10-26-2006 03:23:27
I'm trying to decide which of these 2 dozer to buy. The D6 (early 60's)is a very worn, but usable with direct start. It needs sprockets badly and the under carrage has about 30% left. Price is aroung $8,500.
The other is a HD-11 (early 80's) Fiat Allis. It's a little less worn, but still has alot of wear. Cost around $14,000.
Considering the reputations of each of these dozers and the availability/cost of used parts, which to buy?
RLH
10-27-2006 06:40:02
 Re: D6 Dozer VS. Fiat HD-11 in reply to H2, 10-26-2006 03:23:27
Put berco in google find a dealer in your area .they make good aftermarket tracks or check junk yards for used
Joe in Ne
10-26-2006 21:00:31
Depends what you want to do with it. I have had a D6 in that series and it was a good tractor but a little underpowered for me. I sold mine for $12000.00 and it had about 85% undercarriage. Nice thing is you can get parts fairly easy for them.
H2
10-27-2006 02:47:54
 Re: D6 Dozer VS. Fiat HD-11 in reply to Joe in Ne, 10-26-2006 21:00:31
I'm going to use it around the farm to clean ponds, fence rows, level pads for buildings, fill in a trench silo, take out a few trees, level ground. I just want something that is dependable considering I buy it in decent shape.
Are there after market under carrage parts available? CAT sure is high. Its around 16k for a complete undercarrage assembly set.
Joe in Ne
10-27-2006 12:33:17
 Re: D6 Dozer VS. Fiat HD-11 in reply to H2, 10-27-2006 02:47:54
The D6 44a which is also known as a D6B should be fine for what you want to use it for. If you are planning on removeing trees with it though you really should have sweeeps and for sure need a EROPS. Easy to get killed without one. It will do everything you need although it might take a while. I would stay away from the FIAT/Allis as I don"t think they hold up as well and are a little harder for parts
H2
10-27-2006 14:28:55
 Re: D6 Dozer VS. Fiat HD-11 in reply to Joe in Ne, 10-27-2006 12:33:17
What are sweeps? Is that a straight blade that doesn't angle?
Anything to look out for on this direct drive D6B?
Joe in Ne
10-27-2006 15:39:30
 Re: D6 Dozer VS. Fiat HD-11 in reply to H2, 10-27-2006 14:28:55
Sweeps are the bars that come down from the top of the canopy or erops toward top of radiater. If a tree falls it catches it there. If you don't know much about undercarriage it might be worth your while to pay a local mehanic $100 bucks or so to stop by and check it out for you. Would be money well spent on any dozer you buy. If you could get a chance to work it you might check to see if it runs hot. Pretty hard this time of year though. Good machine, light and easy to move. Direct drive is cheap to fix. I guess if it doesn't look all beat up it will probably work. If it has 30 to 40 percent undercarriage you probly can get 500 to 1000 hours on it before it's totally shot. Probably ten years the way it sounds!
RLH
10-26-2006 08:19:44
Angle is for running parale along a ditch to backfill tilt is 1 or the other corner raising or lowering handy to dig around a tree tilt is good, mechanical angle wouldnt be to handy for most folks has seller used terms like d69u or d6b /d6c standard trasmission is farly easy to work on ive rebuilt some ide be afraid to tackle a pshift also oil clutch is good does it have a winch still need more imfo
RLH
10-26-2006 03:38:59
Like apples and oranges //11 will be heavest if that is a issue its probaly a power shift which is great to run but expensive to work on what model of 6 is it could be power shift or standard tilt or not need more imfo
H2
10-26-2006 17:45:13
 Re: D6 Dozer VS. Fiat HD-11 in reply to RLH, 10-26-2006 03:38:59
I found out the CAT is a straight D6 44A. Whats the difference between a D-6 and a D-6B or C? Is it just the year they were built?
H2
10-26-2006 04:17:04
I think the D6 is a 1962 and is not a power shift. It has an angle blade and is hydraulic.
