Clutch Housing 450C
Remote
10-26-2006 05:14:08
The 4 bolts that hold the clutch housing keep loosening.There are two on top facing one direction and two underneath facing another? In as days time you may have to tighen a couple of times. Whan I replaced clutch the other day I put in brand new bolts. Even added loctite.
Has anybody had this problem and what was the fix. I have some knowledge of machine work but before pulling motor to drill and tap housing I would like to know what someone else may have done to solve, especially how to drill,what sizes, etc. to Tap.
Thanks for all help?
All advice appreciated
JD Red
11-02-2006 16:46:52
 Re: Clutch Housing 450C in reply to Remote, 10-26-2006 05:14:08
Frame rail bolts must be tight, also check frames as they would crack just ahead of where they attach to the steering clutch housings
Roy Suomi
10-27-2006 21:19:20
Once you have the clutch housing out , you might want to check for flatness of surfaces.between clutch housing and trans case. Also check for loose frame rail bolts..
