Speed of shift Thanks Roy
drk
10-29-2006 14:25:38
Roy, I removed the engine on my 450C again. Like you said the cast knuckle was worn about 2 tenths, and when I had reamed out the lever on the other end it was off about 2 tenths. So in all the shaft and end fittings were off a little under a half inch. I put it all back together and adjusted it as per your instructions and it works better than it ever has since I bought the dozer seven years ago.
Roy Suomi
10-29-2006 19:35:22
 Re: Speed of shift Thanks Roy in reply to drk, 10-29-2006 14:25:38
Good for you..Glad to hear it worked out for you...R.S.
