Hi, I looked at the bucket on Friday. It is a light duty 30" bucket. The bad news is that it has had the cutting edge replaced, and then bent a bit in use. Teeth were welded on to the carbon steel edge and all but 1 broke off. (that one is cracked) The correct procedures for welding to carbon steel were obviously not used. There are some other weld repairs where the side walls meets. Still, the body of the bucket is in decent shape, with surface rust on it. Given that I wanted a larger light bucket to adapt to a Ford 723 hoe, a deal was struck and $90 changed hands. I figured that at that price it was a decent deal. I will be getting some DOM tubing to fill the holes and bush down to 1 1/4" for the Ford bucket pin size. The bottom hole is 1 3/4 with a width of 10". Anyone see any problems putting 1/4" wall DOM into the hole and extending 1" in to match the 8" width the Ford needs? Should I gusset the stub or will it being only 1" long be plenty stout? I will use longer pins that go all the way to the outside. The top hole is 1 1/2" with a width of 8 1/4". Again using 1/8" DOM to bush it down and then 1/8" washers to fill the gap. Sound like a plan? Again all input, advice and words of wisdom eagerly accepted! jb
