MF300 track tension adjustment
w williams
10-31-2006 05:14:49
Can anyone tell me how the tracks are adjusted or where the zerk fitting is? I remember using a greasegun to adjust a 200 model, but I can't find a zerk fitting on this 300.(It's probably an early 1970's made in Italy) thanks, mw
murray
11-04-2006 05:07:28
 Re: MF300 track tension adjustment in reply to w williams, 10-31-2006 05:14:49
We had a MF300 and the adjuster is on the yoke. On the side of the yoke you will see what looks like a plug in a hole and right above on the top is another cap. You need to take off the cap on top and under that is the grease zerk. Then you loosen the plug in the side a couple of turns and then you can get the grease in. If you loosen the plug too much it will let the grease out to loosen the tracks. After you get the tracks adjusted make sure to retighten the plug. On ours we welded a nut on the top cap to make it easer to get off.
w williams,
11-04-2006 10:58:21
 Re: MF300 track tension adjustment in reply to murray, 11-04-2006 05:07:28
murry, thank you, mw
w williams
10-31-2006 16:59:39
hectorgemme, thanks, I will look there tomorrow ,mw
hectorgemme
10-31-2006 09:09:35
HI I dismantle a 3366 m.f. hydrolique adjuster and the zerk is on the shaft just being the idler yoke.
