track adjusting cylindrers
ron atchison
11-02-2006 11:15:52
hi, i am in need of a pair of track adjusting cylinders for a 1972 jd 450 crawler. does anyone think i can rebuild the old ones? they have never been off and when i try to adjust they just bypass in the cylinder. where can i get parts? thanks for any help!
Roy Suomi
11-02-2006 15:52:41
 Re: track adjusting cylindrers in reply to ron atchison, 11-02-2006 11:15:52
I ran across a place that makes fabricated track adjusters [ instead of cast cylinders ]. Paint Valley Equipment Millersburg , Ohio..Much cheaper than OEM...
jdemaris
11-02-2006 11:36:47
I suggest you pull them apart first. All the parts are available from Deere - but . . .
Many older 350s and 450s went though several types of seal revisions. The earliest two versions were thin rubber rings and would not hold once the cylinder got worn a bit. The third version is a hard neoprene type seal with a directional lip on it. I think it began to be used with the "C" series. They work great. In our Deere shop, with all the older 350s and 450s, we simple recut the groove in the piston to fit the newer seal on. If you buy a thin old style seal and have some wear, you're wasting your time.
ron atchison
11-02-2006 13:28:46
 Re: track adjusting cylindrers in reply to jdemaris, 11-02-2006 11:36:47
could i get somewhat of a ballpark figure on th rebuild kits. thanks.
135 Fan
11-02-2006 13:36:07
 Re: track adjusting cylindrers in reply to ron atchison, 11-02-2006 13:28:46
I put new seals in my 355D loader because they were relatively cheap. I got mine from an aftermarket undercarriage shop. Maybe a seal place would have them as well. You could polish up the shaft with very fine emery cloth when you take it apart. The track adjusters are pretty simple. Dave
ron atchison
11-02-2006 16:19:00
 Re: track adjusting cylindrers in reply to 135 Fan, 11-02-2006 13:36:07
thanks guys..i had considered rebuilding but i don't think i have the downtime now. i called the place in Pa. and they have the cyl's for $385 each..seemed a bit high but? anyway, i guess i'll get the new ones. thanks to all that have replied!
