streering adj.
U9 U9 CAT
11-03-2006 15:12:02
explain adjustment of streering levers and brakes on a 9U D6 old Cats out of adj. needing advice Thanks for help.
R Harvey
11-21-2006 20:02:24
 Re: streering adj. in reply to U9 U9 CAT, 11-03-2006 15:12:02
Steering clutchs loose there working free play as they wear adjust rods on each lever to have a minnimum of 3 " at the top before they contact the
release bearing { the point that resistance start
to build up ] Steering breaks remove small covers
on rear of tractor under fuel tank and tight or loosen till the pedals go down about half way.
Under the tractor inside each final drive is a set screw with lock nut, remove and clean threads and
oil . turn lock nut well onto the screw. then screw the screw back into the hole gently till it contacts the brake band and in till you feel the
band contact the drum. then back it off 1 round
and hold it and tighten the lock nut. this keeps the band centered and off the top of the drum
when the brakes are released , preventing wear.
Bob/Ont
11-03-2006 18:27:13
Go to the ACMOC board, Old Magnet just posted something from his manual I think.
Later Bob
U9 U9 CAT
11-04-2006 16:44:23
 Re: streering adj. in reply to Bob/Ont, 11-03-2006 18:27:13
Hey Bob that web sight doesn't work what do the go by now. Thanks for the repliy.
Bob/Ont
11-04-2006 18:59:28
 Re: streering adj. in reply to U9 U9 CAT, 11-04-2006 16:44:23
Try it again they are reconditioning it. It just worked for me now.ACMOC, not IBDOZING, it's been down for a while now.
Later Bob
U9 U9 CAT
11-11-2006 19:16:52
 Re: streering adj. in reply to Bob/Ont, 11-04-2006 18:59:28
Thanks Bob I looked again and found some ifo I needed I haven't been to that sight before.
