1940 Cletrack
joe davison
11-03-2006 19:41:13
Hello to all, I bought an old cletrack BG model that was originally set up as a neumatic core driller and it runs great but the water pump started leaking thru the weep hole. I took it apart and cleaned it all up but, can't find any place that can even tell me what kind of engine is in it. Do any of you know? It's a flat head 6 cyl. There is a plate on the lower right front of the block that has SRL - 947205 bore - +060 MB - 010 CR- STD Date- 1262-60 / On the left rear of the block behind the starter are the raised letters --- MOLVIRONB with --- CWG under that. Also does anyone know if cleaveland tractor Co. was bought up by another Co. after their shutting down or any place that sells parts of any kind for these old gems...? All replys are very welcome.
DGH
11-03-2006 20:39:48
 Re: 1940 Cletrack in reply to joe davison, 11-03-2006 19:41:13
The engine should be a Hercules JXC, later ones used the JXD. Cletrac was purchased by Oliver in 1944. White took over Oliver in the mid 60's and crawler production ended in 65.
