Bobcat 610 carburetor question
Brandon Burnett
11-04-2006 18:50:10
I have a 610 with a wisconsin engine and a zenith carburetor on it. I recently rebuilt the carb with a NAPA kit. When running over idle the machine floods out and doesn"t speed up. Does anyone have any sugestions? Should I find a remanufactured carb or a new one? If so where would I find one. Any help is greatly appreciated.
Brandon Burnette
11-07-2006 17:21:10
 Re: Bobcat 610 carburetor question in reply to Brandon Burnette, 11-04-2006 18:50:10
Thaks for the sugestions I will try them this weekend.
Tigerhaze
11-16-2006 07:05:26
 Re: Bobcat 610 carburetor question in reply to Brandon Burnette, 11-07-2006 17:21:10
Did you ever get it working?
Brandon Burnette
11-20-2006 18:10:57
 Re: Bobcat 610 carburetor question in reply to Tigerhaze, 11-16-2006 07:05:26
No the float is not stuck. I adjusted it again and it still floods out. Take out the air ajustment screw and it still floods out. Runs good at idle though, only problem is you can"t do anything at an idle. I am now looking for a new, professionally rebuilt, or a different carburetor. Thanks for the suggestions though.
Brandon Burnette
11-20-2006 18:10:42
Roy Suomi
11-04-2006 19:06:57
Sounds like the float isn't adjusted right if it's actually flooding out..
Tigerhaze
11-06-2006 13:57:20
 Re: Bobcat 610 carburetor question in reply to Roy Suomi, 11-04-2006 19:06:57
It may also be that some small particles got into the carb and caused the float to stick- try LIGHTLY tapping on the carb housing with a hammer.
The float on my carb (Model 500 Bobcat) was stuck and causing fuel to overflow out the side of the carb; it was easily remedied with a few taps.
