OC-46 steering
Phil_in_WA
11-12-2006 10:22:07
My OC-46 would only turn right if I yanked back all the way on the lever. Now I know why.
It is a clutch type steering unit and when I opened it up all the cam rollers from the right side were sitting in pieces on the bottom of the housing.
5 cracked roller fragments, one shaft, one nut and a few washers. THe one visible unit has no roller.
Going to be quite a job to fix so my question is is there anything I should look for as to the cause while I have this all apart.
fort67
11-12-2006 17:16:04
 Re: OC-46 steering in reply to Phil_in_WA, 11-12-2006 10:22:07
when taking apart make the thrush washers were in place. sounds like cam roller came loose.good luck! if you need diagrams and specs be glad to oblige.
