AC HD9B
Tony
12-03-2001 04:28:45
I'm trying to put this tractor back into service after sitting for about 10 years. The only problem I can see is the right brake pedal is dropped all the way down. Anyone know what this could be? Also, I'd appreciate any suggestions anyone might have about getting it going again. I'm changing all the fluids and filters, at least all the ones I can find. Thanks for any advice,
Tony
Mike Wurth
12-04-2001 22:01:31
 Re: AC HD9B in reply to Tony, 12-03-2001 04:28:45
Tony, take the four small covers off the left side of the engine and soak the pistons down with diesel or some other lubricant befor starting. If you have good batteries turn the ingine over without giving it any fuel untill you get some oil pressure. Make sure the emergency shut-off will work in case you need it or use a piece of plywood over the air inlet to stop a runaway engine. The linkage could be broke on the brake or any number of things,,just have to dig and look,,,good luck,,,,Mike
Tony
12-05-2001 04:38:54
 Re: Re: AC HD9B in reply to Mike Wurth, 12-04-2001 22:01:31
Thanks for the advice Mike. I'll let you know how it goes.
