Looking at a Mitsibishi ME 40 escavator right now that a neighbour has for sale. It has 4000 hrs and it is on steel tracks. Weighs about 5-6 ton (4000 kg machine).One of the front idlers has spit its bushings out (I assume, there is a pile of slop!) and the other side the idler yoke tracks are worn and the idler has been over extended and is flopping half out of the idler track. The sprockets are good but the chains on the tracks are worn down a lot. Rollers and idlers look ok, pads are worn but ok. The machine runs and works well, everything is tight except the linkage at the bucket. It looks like the grease fitting there has been knocked off for a while. Someone reconfigured the controls via the quick connects then tried to put them back but the rotate via the joystick just causes the relief valve to operate. Looking inside one of the quick connects is off the valve block. The foot pedal rotate works fine. The machine drives well, both motors turn the tracks well, drives straight. The fellow is asking 8000$ Canadian for it. I understand it was also sold as a Cat model too but can't find a cross reference to what mitsu models are which cat models. There are no mitsi dealers locally only cat so I'd like to price the parts to repair the undercarriage to see if the guy is asking a fair price.
