H3
Jim
12-03-2001 19:58:55
I have a AC H 3 crawler, first off I cant get the adjusters for the track to turn, any ideas? I am thinking about trying heat from a torch, is there any reason why this cant be tried? second, I keep breaking starters, I have been told it is timing but the timing is dead on, could it be the ring gear? Also does anyone know where to find used parts for a H 3? I need one roller, it is froze up, I have worked a lot on wheel tractors but this is my first with tracks so its all kind of new to me, although I am finding a lot of similarites between wheel and tracked,, thanks,,,,Jim
Nate
12-06-2001 19:40:53
 Re: H3 in reply to Jim, 12-03-2001 19:58:55
Jim,I am located in western Pennsylvania and have found one place for new and one for used parts for an H-3 and HD-3. Where are you located? My HD-3 never gave me any trouble with the starter. I think you will find some similarities between the H3- HD3 and the AC D15.
glenn
12-05-2001 11:58:00
Yes, heat is the only way to get them to move. and a very big wrench,[have you losened the two small lock bolts??} I havent heard of that starter trouble before.You dont want to buy a used roller,unless your shell is worn out. They are very exspensive and hard to find.if you find a used one thats good, $100-300 is the going rate.New shell`s are even more $450 is the last price i heard.If your shell is still good,Id reccomend rebuilding it[should be under$100.00] keep in mind that it will take alot of work to replace that one roller.GOOD LUCK GLENN
Jim
12-05-2001 12:07:38
 Re: Re: H3 in reply to glenn, 12-05-2001 11:58:00
Thanks Glenn, the roller is pretty good yet, just froze up and wont turn, it has wore down the one side so that the lip is gone, I am sure the wear is from the tracks riding on the frozen roller, a local welding shop says they can put a new lip on it, they charge 35$ per hour, said its about a 2 hour job, I think I will just have that done,,, Thanks,, I will let you know if heat does the trick on the track tighteners,,,,Jim
glenn
12-09-2001 11:04:32
 Re: Re: Re: H3 in reply to Jim, 12-05-2001 12:07:38
If you need parts try this guy. sumerx implment,ask for ivan 989-379-2721 good source for parts.
