wisconsin ve4 gas engine
troy21
11-19-2006 17:13:30
i got a wisconsin ve4 motor.. and was wanting to know how to time the darn thaing.. it has the magnito not the distribitor.. and the only marks i see on the front flywheel is the "DC"..there is no marks on the shroud some one has cut the shroud up for an altnator..lol..and last question is.. how can i tell if the mag is sparking..thanks in advance
R Harvey
11-21-2006 18:58:30
 Re: wisconsin ve4 gas engine in reply to troy21, 11-19-2006 17:13:30
#1 cyl is next to the flywheel same side as the mag,
# 3 is beside it, #2 is next to the flywheel
opposite side to the mag. #4is beside it.
TDC mark on vane of flywheel straight out from key
way on crankshaft should be straight up for DC [in line with governor shaft] Leave flywheel in this
position and install mag. so that the marked tooth
on the mag drive gear is visible in thelower half
of the inspection hole [ plug on side of gear case]
distributer terminals are numbered. Adjust position of mag so that impulse trips slightly after TDC mark #1 cylinder Breaker point setting when
fully open is Fairbanks Morse .012" Wico .015" "Watch the short crank .broke my wrist 3 places"
troy21
11-21-2006 15:25:40
thanks RAB.. mine has had a starter attached to it but it is bad.. it wont crank it hardly at all.. its draging rilly bad... does anyone have a starter for this engin...
RAB
11-20-2006 23:19:31
Keyway on top and align timing marks on mag and mag drive gear, I think. No problem with being 180 out as the mag fires at crank speed, not camshaft speed, so fires on exhaust as well. Set impulse to trip a smidge after tdc as when they kick back that little start handle can go flying! Go from there. If I find my book, I will check details.
Regards, RAB
troy21
11-20-2006 16:34:07
well guys i thaink i found the problem.. i took it to a guy that luvs to work on this stuff and he sayed that my condinser was not holding a good enough charge to go threw the cap and threw the plugg.... its week..lol.. so tommarow will see if we can start it.. any tricks to timing this old beast
troy21
11-20-2006 10:48:15
yea im kinda new to all this.. this motor was trying to start but never would.. so i thought it might have been outta time.. so i took the mag out and gaped the points.. can i just put the jumper cable to the engin block and turn it by hand.. cus its a pain to put in and out of the motor.. any ideas of why it wouldent start befor.. it tryed but never did start, was i right about it mabe outta time a lil
oldcraneguy
11-20-2006 03:03:29
Troy, If the mag is installed on the engine just pull the plugs and lay em on top of the engine with the wires hooked up (mark or # the wires so ya dont get em crossed) and roll the engine over with the starteryou should see spark either at the electrodes or where the plugs ground, if on the other hand the mag is on the bench you need to ground it (ground rod and jumper cable works ok for this) and turn the drive I always put em in a vise after one bit me years ago causing me to drop it on the floor breaking a brand new cap, the only wisconsin I had a vg4d had an impulse drive and you could turn it by hand and it would fire. A word of caution here, any minute now someone will come here and tell ya to just hold the mag in one hand and turn it with the other (was tempted myself WEG) bad Idea! (thats how I broke the new cap on mine my "buddies" thought it was funny till the pieces of cap were seen all over the floor)...good luck
