cable length D6 9U blade
U9 U9 CAT
11-20-2006 13:29:42
need to make sure cable length is 68 ft.
David Manring
11-23-2006 10:43:56
 Re: cable length D6 9U blade in reply to U9 U9 CAT, 11-20-2006 13:29:42
Cat made a front CCU (cable control unit) model 10 I think? I learned on a D6 8u with the front unit, and also ran the rears on 7's. As the other post says , you learn to keep that cable tight, no slack or you will be threading cable!!!!
Old Magnet
11-20-2006 19:52:36
Front cable control uses 40 ft.
Rear cable control uses 60 ft.
Both 1/2 in. 6 x 19 Warrington, right Lang lay, wire strand center, pre-formed, improved plow steel type.
U9 U9 CAT
11-21-2006 18:58:45
 Re: cable length D6 9U blade in reply to Old Magnet, 11-20-2006 19:52:36
I don't understand front cable aand rear cable? The winch is a 25 model two drum I would like to make a riper or root plow any ideas would be good help. thanks for the info.Mike
U9 U9 CAT
11-20-2006 18:48:18
I got a job I have to try and finish tomorrow. So I had to go to town before closing, and get some cable. Well I got 68 should be anough. thanks for the quick repliy Mike
RLH
11-20-2006 18:35:27
65 was the 1st thing that came to mind Iremember pilling brush in my younger days and backing off the pile with slack in the cable blade would drop and break cable old mechanic let me change cable i learned quick not to do that
