jd450c liners
jholliday
11-21-2006 03:30:13
having problems getting the liners out diesel engine any easy way without breaking them i have done many big trucks no john deeres thanks for any advise
jholliday
11-22-2006 05:34:50
 Re: jd450c liners in reply to jholliday, 11-21-2006 03:30:13
would u know head and rod bolt torques is there a liner protrusion spec
MN Scott
11-22-2006 10:29:11
 Re: jd450c liners in reply to jholliday, 11-22-2006 05:34:50
The liner protrusion spec's are .0010 to .0040 above the deck surface with no packing rings on the sleeve. Rod bolt torque is 65 ft lbs oiled. Mains are 85 ft lbs dry. Head bolt torque is 110 ft lb, dry taken up in three steps. Valve tappet clearance is .018 exhaust and .014 intake. If the puller fails to remove those sleeves you can weld them out. Run several beads from top to bottom on the inside of the sleeve. The welds and heat contract the sleeve and it will slip right out.
jdemaris
11-21-2006 05:46:46
Liners on a C series slip in by hand when clean. So your's must be pretty rusted/corroded. All else fails, use a sleeve-puller. I done a few just by putting a bottle-jack underneath. But, I've also had a few that the entire crawler went up in the air and the sleeves would not pop out.
jholliday
11-22-2006 05:31:19
 Re: jd450c liners in reply to jdemaris, 11-21-2006 05:46:46
thanks very much tried a bottle jack as u said raised up crawler i have a puller coming
