Case need clutch
megamc
11-21-2006 18:10:11
My early Case 580 backhoe needs a starter ring gear and clutch. Can I removed the engine from the front of the machine to access the flywheel or must I split the tractor. What is the best way to procede.
timg
11-23-2006 03:21:17
 Re: Case need clutch in reply to megamc, 11-21-2006 18:10:11
I have a 580B and I had to split the tractor. Its not as bad as you think. If you do it on a concrete floor and have a good jack on wheels. You only have to seperate it about 10 inches to work on it.
