Tried to start the PH 150 crane today
lfc
11-25-2006 18:56:09
With warm temperatures this weekend, I figured it would be a good time to see if the Waukesha 6BK would start. I cleaned out the carb and fuel pump and changed the oil. I was thankful that only a few spoonfuls of water came out before the oil. With the plugs out I spun it over with the starter and built up oil pressure right away. Unfortunately, I then realized that only two cylinders had much compression, with the others having basically none at all. I guess I have a few stuck and/or dirty valves. I tried to start it anyway thinking the valves might loosen up, but only heard a few puffs from it. Pulling the head shouldn't be too hard, so if the weather stays reasonable I'll give it another try soon. I'm anxious to hear this run before winter!
I also received the operator's manual that I ordered, and it has really helped me figure out all of the controls. The one thing I do not understand is how the boom hoist brake (which is normally on) knows to release when the boom hoist clutch is engaged?
daves 40 acre
12-01-2006 06:44:53
 Re: Tried to start the PH 150 crane today in reply to lfc, 11-25-2006 18:56:09
Haven't been on this board in a while, glad to hear you are making progress, oldcraneguy idea of loosening tappets is a good idea have done itmyself and it worked. Keep us posted on your proggress,it is neat to see someone intrested in something like your PH goodluck the world is watching
oldcraneguy
11-28-2006 03:30:15
You might not have to pull the head, try pulling the tappet covers and putting a small prybar between the springs and see if you can get the valves to move that way, worked for me once on an old plymouth flathead, dont get carried away and bust em though.
RLH
11-27-2006 17:15:56
appreciate the update ive been wondering about it
swms301
11-27-2006 07:28:20
Glad to hear you are making some progress. sounds good that it turned over and made oil pressure. Keep us updated on your progress.
