T9
Mark Torrence
11-26-2006 17:14:45
I have a T9 crawler with a 335ci 4 cyl gas engine. Don't know the year. I refuses to run. It will start and run good for a few seconds then unless I keep the choke on full it will die. Even then it will barely run. It has about 4 lbs fuel pressure and good flow. It doesn't smoke. I think it is the carb. I have had it apart and cleaned it. No help. Any ideas??? Anyone know where I can find a rebuilt carb?
traper
11-29-2006 18:27:34
 Re: T9 in reply to Mark Torrence, 11-26-2006 17:14:45
some IH carbs had a screen on the intake fitting where fuel line enters carb ...check...also is there a plug in in bottom of carb? pull it crank engine ssee if you have fuel flow?
yardguy
11-26-2006 18:05:16
It sounds like a vacuum leak somewhere maybe around the base of the carb or on the intake manifold. spray small amounts of starting fluid around the area if the idle shoots up you have found your leak HtH
Vaughan
11-26-2006 18:18:25
 Re: T9 in reply to yardguy, 11-26-2006 18:05:16
Aerosol carburetor cleaner, CRC, will change the engine RPM’s and will not damage an engine. I use it to start "stuborn" gasoline engines.
