Hitachi Bulldozer
Tom Shufelt
12-01-2006 14:12:01
Anybody have any informations on 1992 Hitachi Bulldozer Model DX45M. I am looking for manuals or information on track adjustments.
135 Fan
12-01-2006 22:58:28
 Re: Hitachi Bulldozer in reply to Tom Shufelt, 12-01-2006 14:12:01
It could also be a rebadged JD. Dave
ajk
12-01-2006 18:36:56
Only ever come across one of them nice little tractors here in the UK,as i remember I think it was badged Fiat Hitachi,the tracks had hydraulic adjusters,ie you pump them up with a grease gun with ordinary grease,you will find a grease fitting if you look around the recoil spring,do not put the tracks too tight,there needs to be a slight sag in the between the top roller and the idler about 35mm for steel or rubber tracks,run the machine backwards and forward,always stop after going forward so the slack is at the top to check the tension. good luck with it.
AJ
