12 volts 2 24 volt starter
ross in ns
12-06-2006 15:55:09
hi all wondering what the way to hook up 2 12 volt batterys to get 24 at starter my machine has 24 volt start and has ben very slow to turn i found out it is only getting 12 volts poor wireing job previuos thanks
ajk
12-07-2006 16:14:04
 Hook up sketch in reply to ross in ns, 12-06-2006 15:55:09
A rough sketch for a negative ground 24V system
AJ
Click on the link
troy21
12-06-2006 16:24:49
 Re: 12 volts 2 24 volt starter in reply to ross in ns, 12-06-2006 15:55:09
all u do is take the 2, 12 volt batteries.. and conect the positive of one to the negative of the other.. then that leaves u with a positive on one battery and a negitive on the other.. thats how u do it in a series, like in a big rigg,
Tigerhaze
12-07-2006 14:22:14
 Re: 12 volts 2 24 volt starter in reply to troy21, 12-06-2006 16:24:49
If you decide to connect two 12V batteries in series, make sure they have the same capacity (same amp-hour rating).
