3/53 Detriot Oil Loss
jj18
12-07-2006 10:40:41
I have a 3/53 Detroit in a Dynohoe that is losing oil out of what the owners manual says is the blower vent tube (right side behind the starter). There is no crankcase pressure out the breather, no pressure at the oil fill, or at the dipstick. I have changed the blower air filter thinking it was restricted and did not fix the problem. Any ideas?
Lee Bradley
12-11-2006 10:49:40
 Re: 3/53 Detriot Oil Loss in reply to jj18, 12-07-2006 10:40:41
What oil are you using? Should never use mutli-weigh oils in Detroits.
Lee Bradley
12-11-2006 12:53:00
 Re: 3/53 Detriot Oil Loss in reply to Lee Bradley, 12-11-2006 10:49:40
Check the oil requirements listed by Detroit:
http://www.detroitdiesel.com/support/on-highway/manuals/Lubricants_Fuels_Coolants/index.asp
chip man
12-10-2006 13:51:37
It is normal to have a small amount of oil drip from the vent tube.
JLB2
12-07-2006 11:52:03
more often than not its the seals on the rotors in the blower that are leaking by,also comes from not running hot enough.engine temp in a detriot is very critical to how they preform.it could also be a wrist pin retaining disk but that usaully shows up in a big leak and lots of smoke.how much are they leaking?
jj18
12-11-2006 09:48:20
 Re: 3/53 Detriot Oil Loss in reply to JLB2, 12-07-2006 11:52:03
About a quart per 2 hours engine use. Enough to follow the trail. It does smoke alot.
Chip man
12-11-2006 19:07:50
 Re: 3/53 Detriot Oil Loss in reply to jj18, 12-11-2006 09:48:20
That is a lot, probably the blower seals. I ran a machine with a 6V53 that had broken piston rings, and it would leak out a couple of cups of goo in 8 hrs.
jj18
12-14-2006 09:35:52
 Re: 3/53 Detriot Oil Loss in reply to Chip man, 12-11-2006 19:07:50
Sounds like I have my winter project. Thanks everyone, I will let you know what I find
