excavator trapped in flood waters
two mile
12-08-2006 19:03:09
Last week we had almost 4 inches of rain overnight. Had our 690B parked about 80' from the ditch, on a little knoll. We ended up with a flood that covered 3/4 of the track. I just wonder what all I will need to check/replace? track rollers? drive motors? tensioners? What do you fellas think.
j schlosser
12-20-2006 09:32:24
 Re: excavator trapped in flood waters in reply to two mile, 12-08-2006 19:03:09
I have a 690B also. The propel brake (between the drive motor and final drive) has a vent on the top. If it got water inside, the steel brake plates will rust and cause problems. I would open the drain plug on the final drives and see if there is any water at the bottom. Change the lube if there is any doubt, a lot cheaper than rebuilding final drives.
Jack
2x4
12-08-2006 21:05:34
you are ok as long as it didnt get into the cab. Then you would have problems.
Roy Suomi
12-08-2006 20:03:06
Shouldn't need to check anything..They're made to " mud "..What's the difference between mud and water...???? There's no vents that low to allow water in..If you feel strongly about it , Check the finals...
