JD450 brake bands
John Wood
12-11-2006 10:59:23
Hi,
Is there any general preferance to the type of mounting for the brake band material and if so why?
I recently worked on one of the steering clutches on my machine. I found that one the bonded brake pads had come off of the metal brake band, thereby causing looseness and loss of function. I am considering replacing all the pads with thicker material (say 1/4"thick) that is rivetted with brass rivets (to save the outside of the drum). In my case where there would not be much more than a couple of hundred hours of use per year, I think this installation would work.
Have any of you tried with rivetted shoes, and if so how did they perform/last.
Thanks for any comments - all appreciated.
J.
Athony
12-13-2006 18:15:09
 Re: JD450 brake bands in reply to John Wood, 12-11-2006 10:59:23
i used to work for a company that relined heavy duty and industrial brake shoes and bands we always used brass rivets and never had a problem with them
Roy Suomi
12-11-2006 15:37:00
Bigger is not always better..I can see your logic wanting to slightly overkill the brake linings...But there's a reason someone else hasn't done that before...There's not the room for thicker linings..Riviting linings on is good, not so sure of brass rivits..I would prefer steel rivits myself..I would think the brass rivits would loosen up..My thoughts , do watcha want....
John Wood
12-11-2006 16:58:45
 Re: JD450 brake bands in reply to Roy Suomi, 12-11-2006 15:37:00
Hi Roy,
Thanks for your comments - make sense. Sometimes we don't always see what others do, hence the need for questions and ideas.
J.
