cat 955l track ram
John H Reid
12-11-2006 11:43:45
I HAVE AN OLD 1974 TRACK LOADER AND THE RIGHT TRACK RAM COLLAPSED. ADDING MORE GREESE DOES NOT MOVE THE RAM AND CAN NOT FIND WHERE THE GREESE IS GOING. OPENING THE VALVE SHOWS GREESE GOING THROUGH THE PORT. ANY SUGGESTIONS?
hectorgemme
12-12-2006 16:04:30
 Re: cat 955l track ram in reply to John H Reid, 12-11-2006 11:43:45
HI The seal number should be 4m7021 and you need too a ring 4m7022.
Bob/Ont
12-11-2006 12:39:58
John, it goes back into the front recoil spring pilot behind the cylinder. If you unbolt the front plate that the idler rod is welded to and force the idler ahead and block it you should be able to change the seal on the piston. Later Bob
John H reid
12-12-2006 10:01:48
 Re: cat 955l track ram in reply to Bob/Ont, 12-11-2006 12:39:58
Thanks Bob. Will look into replaceing the seal. and look for a parts list and a replacement document.
John
Bob/Ont
12-12-2006 12:24:12
 Re: cat 955l track ram in reply to John H reid, 12-12-2006 10:01:48
John, the cylinders some times get worn inside too and will hold in some spots and not in others. If the seal looks good you may need to pull out the cyl but we will get into that later if we need to.
Later Bob
