2010 DOZER
Terry Clark
12-14-2006 08:53:02
Would like to talk to someone about a 2010 john deere dozer. I"m looking at one that runs good but is missing back pump the blade will not raise up if anyone could help please contact me. Thank you
Lavoy
12-16-2006 08:00:11
 Re: 2010 DOZER in reply to Terry Clark, 12-14-2006 08:53:02
Flywheel HP on a 2010 is 52 which puts it well above a 350. The torque may not be alot more, 350's are quite good in that respect. As to clutches, as JDEMARIS said, that has nothing to do with the 2010. Parts can be a little hard to come by compared to 350/450 but not as difficult as you might think. Its like anything else, if you abuse it, it breaks.
Pump should not be that hard to find. Check the undercarraige, that can cost you alot of money in a big jurry.
Lavoy
jdemaris
12-16-2006 08:33:09
 Re: 2010 DOZER in reply to Lavoy, 12-16-2006 08:00:11
What exactly did I write, that you refer to with "As to clutches, as JDEMARIS said, that has nothing to do with the 2010?"
What has "nothing do do" with a 2010? Are you saying that keeping a crawler dry - or keeping pressure off the steering clutches for long-term storage does not help with a 2010? In regard to power - I've never seen torque-specs for the 2010, just run them and had them on the dyno. I don't consider them "dead" as the one guy stated - but not an awful lot more powerful than a 350. Most 2010 deisels will put out 46 horse on the dyno, whereas a 350 will put out 38-39 and the first 450s around 54. Those figures seem to coincide with how much and how fast the crawlers push dirt.
Lavoy
12-16-2006 09:35:56
 Re: 2010 DOZER in reply to jdemaris, 12-16-2006 08:33:09
I was reiterating what you said, that the clutches sticking is a function of a dry clutch, and not a function of it being a 2010. Therefore I said that the steering clutches sticking had nothing to do with it being a 2010, and meant that he should not be afriad of it for that reason.
Lavoy
jdemaris
12-16-2006 09:44:25
 Re: 2010 DOZER in reply to Lavoy, 12-16-2006 09:35:56
Okay. I was responding to RLH saying his steering clutches in his 2010 got stuck whenever it sat. That was a common complaint with all the dry-clutch crawlers - but it can be pretty easily prevented. That was, and is , my point.
RLH
12-15-2006 03:43:19
biggest dud I ever owned was a 2010 diesel broke down all time head problems constantly . steering clutch compartment drew moisture and things would stick if let sit any time at all !!!RUN!!!!! !!
jdemaris
12-15-2006 05:52:55
 Re: 2010 DOZER in reply to RLH, 12-15-2006 03:43:19
Any dry-clutch crawler will do that - if has the standard fiber clutch disks. And, just about any dry clutch crawler will be fine and not get stuck - if you take some care with it. Drain the steering-clutch housings once in awhile, or - install vents, keep the machine covered, and tie the steering-clutch levers back when put in storage. I can leave my Deere 1010, 1010, 350, or Allis HD4 and HD6 parked for any amount of time and they don't get stuck. In regard to the 2010 crawler being "dead" - I guess that depends on what you compare it too. At 40 horsepower - it has slightly more pushing power than a later Deere 350 crawler, and it's about 10 horse shy of a 450.
CH
12-14-2006 09:50:30
I have several 2010 parts machines Email me for my link
Jshart
12-22-2006 11:30:09
 Re: 2010 DOZER in reply to CH, 12-14-2006 09:50:30
My 2010 runs great when it’s running… But the moment you start have problems with it your in trouble. If a repair is need, it’s usually something major. If you work on it for a few weeks and get it running again, it’s got plenty of power for a small machine. Then something else breaks and I have to invest more time and money to get her going again. Rebuilt pumps are available at some JD dealers, you just have to call around (Had to fix that a few times too). If you want my opinion, spend a little more money and get yourself a nice Caterpillar..
