Cletrac AG-6 Specs?
Bob Kirk
12-07-2001 17:14:04
Can someone please tell me the HP of a Cletrac AG-6? Is it heavy enough and geared low enough that it would pull heavy trailer loads of wood (maybe 2500 lbs.) up a steep hill without any trouble?
Any particular weak points of this model crawler?
Thanks very much.
george md
12-07-2001 22:41:12
 Re: Cletrac AG-6 Specs? in reply to Bob Kirk, 12-07-2001 17:14:04
bob , I have a cletrac AG-6 , it will pull any load you would like to pull.Keep the oil level up in the trans and finals. also the rollers and
front wheel lube with 90 or 140 gear oil depending on season, do not use heavy grease as those parts
have bushings not bearings. they have a drip oil sys in the roller and frt wheel that will not work with grease.That is why it has 1/4 inch button
head fittings , grease gun for that fitting is called a volume pump .
george
