Komatsu D20-A6 Oil reservoir
BradF
12-16-2006 06:41:22
My dozer has two oil reservoirs under the driver seat, starboard and port. The starboard has a dip stick and the port has a breather. Both have drain plugs underneath. The maintenance manual has instructions for replacing the starboard oil, but nothing on the port side. The shifting gears seem to be contained in the port side. I've noticed quite a bit of dryness when shifting, so I poured a little oil through the breather hole and it helped. I checked, with air pressure, and the port reservoir is air tight, even when the starboard drain plug is removed. Should I clean out and fill the port side with oil? Any advice would be very much appreciated.
