case 580b rebuild
case580b
12-23-2006 19:19:28
I have a 71or72 case 580b with a 188d I think I cant find a tag were would it be? The engine is in need of a rebuild on the top end. I have looked for a kit for just the top end but have not found one. Is there a kit that just includes sleeves, pistons and rings. The reason for just the top is because the bottom was rebuilt shortly after my dad bought it 15 years ago and has not been used more than 1500 hours sense. I also don’t have a lot of money to spend on parts so I don’t want to replace thing that don’t need fixing. I would like to get the engine back up on some power and some less smoke so I can use it more than in the past. thanks for the help
stressfree
12-27-2006 02:16:24
 Re: case 580b rebuild in reply to case580b, 12-23-2006 19:19:28
marlowe how many years did they use that 450 188d engine.having rough time finding block.probley cheaper to buy a tired backhoe for the engine.my 188 is probley a 66 year.do all 188s have different ports or taped holes for add ons?
marlowe
12-26-2006 17:31:00
just doing a 450 crawler with a 188 if your going to open it up do it all kit was 500 pls gaskets make sure you get the ser. no off it kits differ do it right the first time you will save on the long run MAKE SURE YOU SHOP AROUND PRICES HAVE A WIDE RANGE
CH
12-24-2006 22:53:25
How about $540. for what you want. Email me for my link
td5doug
12-24-2006 13:22:03
The serial # for the tractor should be on a plate on the RH side of the steering column.
The engine serial # is on a plate on the RH side of the engine just aft of the oil filter.
EQUIPMENT PARTS SOURCE INC have complete kits for the late production 188 for $635.00
I can't seem to post a link to their site here, it won't let me.
JCSinGA
12-24-2006 06:15:05
To rebuild the engine as you say the only thing you wont use from a COMPLETE kit is the bearings, but it makes absolutely no sense to have the bearings there and not put them in. I'm sure you can order just the parts you want to replace but would probably be cheaper to get the entire kit.
