Bob / Hector, Thanks for your help. The winter held other priorities for me, and now I've chased all the wasps out of my loader and started working on it. I found the suction screen under the cover bob describes, and cleaned it - it was fairly plugged with assorted trash. I also found the tall filter house on the pressure side and will get a new cartridge filter for that as hector described. I also found the screen and magnets on the transmission and cleaned them - they were in pretty good shape. I filled up the trans, and drove the machine back and forth, going through all the gears, topped off the level and rechecked. I let the machine sit overnight and the transfluid was clear last night but now is slightly milky grey, and appears lower on the stick. Also, the steering clutch case oil level appears much higher again. Also, I siphoned about 10 gals of dirty oil out of the bottom of the machine around the steering clutch case. There is one large hole on either side of the machine where the supports for the operator platform bolt on. It was out of these holes, notably the right side one that I siphoned all the oil. So, I conclude that somehow all the oil I add to the transmission makes it's way into the steering clutches, and then overflows out somewhere down deep in the machine and collects until it is so full that it flows up out of that hole on the right side of the machine and runs out the back all over the counterweight. Do I have some cracked casting or transmission case? Also, probably a mistake (obviously) but I had been using tractor transmision oil - 303 in the trans / converter. Maybe that's too thin, and I need to put in straight 30 weight as some others have posted? Would that help? What if I went to a heavier oil - 80/90? Would that damage the converter or the trans?
