555A Ford, No drive
JCSinGA
12-29-2006 18:39:59
I dont have a manual on this hoe can someone tell me where to plug in to check trans. psi and what should psi be?
It's the old story "Was working fine till it quit" LOL.
Roy Suomi
12-29-2006 20:48:55
 Re: 555A Ford, No drive in reply to JCSinGA, 12-29-2006 18:39:59
Bottom of engine clutch housing , there's a plate..Pull the plate , inside there you'll find the torque converter..Somewhere in there you will also find an oil tube hanging there. Pull the plug and install a gauge to read at least 200 lbs..If I remember correctly , pressure should be at least 120-135 lbs...in gear, rear wheels off the ground, blocking under swing post so you don't get run over....
