leaky main
Lauro
01-02-2007 10:38:33
cat d6 leaks oil into clutch need ideas on fix. does it have seal any help is welcome, thanks
Old Magnet
01-02-2007 12:26:03
 Re: leaky main in reply to Lauro, 01-02-2007 10:38:33
If it is a D6 with the D318 engine there is no seal at the rear of the crankshaft. Just uses a reverse thread to pull the oil back into the crankcase. Leaking seals on the pony crankshaft and/or seal on the pony pinion clutch shaft will dump oil in the clutch housing.
Lauro
01-03-2007 08:54:58
 Re: leaky main in reply to Old Magnet, 01-02-2007 12:26:03
it is a d6 with 318 but has been coverted to electric start on the main and pony has no oil or water in it. thanks
