JD 300 crawler loader, 1958 3 cyl diesel
ams
01-04-2007 05:38:38
Starter went out and we're having a devil of a time figuring out how to remove it. The lower starter housing bolt is set between the starter housing and engine block, can't fit a socket & extension on it due to spacing.
How does the starter come off of this engine? Is there a special tool for the lower bolt?
jdemaris
01-05-2007 11:25:50
 wrench photos in reply to ams, 01-04-2007 05:38:38
I've done it many times without the correct tool - but here are two photos of two versions of the tool made for the job. One is an OTC wrench that Deere sold under # JDE80. It is single sided. The other, sold by Snap-On has two sides and works on many Deere starters and injection pumps. It is Snap-On # B4400.
third party image
third party image
MN Scott
01-06-2007 07:06:02
 Re: wrench photos in reply to jdemaris, 01-05-2007 11:25:50
If you need the JDE80 version of this wrench there is one on ebay, item. 320068013190.
2x4
01-05-2007 22:31:06
a half moon wrench will work if you use a grinder & notch out under the boxend just right & also grind the boxend head so it is slimmer. then you can get 1/8th turn at a time. Didnt realize wrenches like these existed.
CH
01-05-2007 03:16:55
 Re: JD 300 crawler loader, 1958 3 cyl diesel in reply to ams, 01-04-2007 05:38:38
If you find the serial number i can tell you what year it is . I also have New steering clutch kits or any parts you may need for the sterring. I also have many new and used parts for that machine as well as manuals. Email me for my link
ams
01-05-2007 04:22:17
 Re: JD crawler loader, 3 cyl diesel in reply to CH, 01-05-2007 03:16:55
Thanks but I can"t do anything with the machine until I figure out how to loosen the lower starter bolt. Nothing I have fits back there. I don"t even see how a bent 9/16 wrench will do us any good.
Lavoy
01-05-2007 07:48:30
 Re: JD crawler loader, 3 cyl diesel in reply to ams, 01-05-2007 04:22:17
The starter on a 4020 is kind of the same concept. You use a 9/16" wrench that is bent in a horseshoe shape. I just saw them at Sears not too long ago, and at another auto parts store. Also look in from the end, you should be able to put a couple extensions together with a 9/16" swivel socket as well.
Lavoy
a ms
01-05-2007 08:02:56
 Re: JD crawler loader, 3 cyl diesel in reply to Lavoy, 01-05-2007 07:48:30
Would you mind if I also asked this at your mssg board?
Lavoy
01-06-2007 08:14:02
 Re: JD crawler loader, 3 cyl diesel in reply to a ms, 01-05-2007 08:02:56
Not at all, go right ahead, that is what it is there for.
Lavoy
2x4
01-05-2007 00:58:41
If there is a I.D. plate it is below the seat between your legs
jdemaris
01-04-2007 06:40:20
There is no such thing as a 1958 300 JD crawler. I assume you've got a 1966 or newer 350? Yes, the bottom nut/bolt takes a special 9/16" bent wrench. You can get it from Deere, OTC, Mac or Snap-On. Some people who don't own one, either bend a wrench thus making their own, or use a long screwdriver or chisel and simply knock it loose with a hammer.
ams
01-04-2007 06:58:14
 Re: JD crawler loader, 3 cyl diesel in reply to jdemaris, 01-04-2007 06:40:20
Very good, will investigate.
I"m sure of the 3-cyl diesel and tracks. The front is a skip loader bucket and it originally came with a backhoe. Would love to know what we have.
jdemaris
01-04-2007 07:18:03
 Re: JD crawler loader, 3 cyl diesel in reply to ams, 01-04-2007 06:58:14
If it's a crawler with a three-cylinder engine, it's a 350. It's the only three-cylinder crawler Deere made. Previous 1010 model made 1960 was a four-cylinder.
ams
01-04-2007 07:22:57
 Re: JD crawler loader, 3 cyl diesel in reply to jdemaris, 01-04-2007 07:18:03
Thank you, this is very helpful.
While I have your ear.. :o)
The tractor's right brake hasn't worked since we bought it several years ago. We steer with the left brake by going forwards/backwards. What is involved in repairing a brake?
jdemaris
01-04-2007 07:50:18
 Re: JD crawler loader, 3 cyl diesel in reply to ams, 01-04-2007 07:22:57
Could be a simple linkage and brake-band adjustemt or require a major tear-down.
