? about a td6
mike jenezon
01-07-2007 10:08:05
hi hopin someone here knows a bit about a td6 block, looking at one and the man who owns it says it has a cracked block behind the inj. pump and it leaks water into the pan and outside said it had a patch over the break and someone took it off tried to fix it . now heres what is funny there is a massive oil leak behind the pump and this would be directly below the camshaft, dosn't seem like there should be any water that low in the block . runs great undercarriage is decent . i suspect that it tossed a rod at some point and ventillated the block and someone fixed it but did a poor job of a block repair . and it is leaking oil it is running hot but the rad is plugged dang near solid . any ideas thanks mike
traper
01-07-2007 17:32:58
 Re: ? about a td6 in reply to mike jenezon, 01-07-2007 10:08:05
Mike If that engine is runing hot beware of cracked head. M D emgine is same.Oil leak sounds like crack into main oil gally I have a td6 that i installed td 61 engine much more power.Where are you located? Im in Pa.
