TD9 cylinder sleeves outer diameter.
Eddie Olive
01-10-2007 17:41:22
I was wondering if the outer diameter of the sleeves on a TD9-91 series crawler are the same as the ones in an earlier model. I own a parts crawler with excellent sleeves, and they are the 4.5 inch sleeves, but I understand that the 91 series had a bigger outside diameter than my 1954 parts tractor. Any ideas.
hectorgemme
01-11-2007 12:43:53
 Re: TD9 cylinder sleeves outer diameter. in reply to Eddie Olive, 01-10-2007 17:41:22
the earlier td9 sleeve is 4 13/32 and the serie 91 is 4 1/2
Eddie Olive
01-11-2007 15:07:13
 Re: TD9 cylinder sleeves outer diameter. in reply to hectorgemme, 01-11-2007 12:43:53
I was wonering about the outside diameter of sleeves, as there was a sleeve you could get for the earlier model that was 4.5 inches inside diameter but it was a thiner sleeve. I was wondering if the 91 series has the same bore in the block as the earlier model has, as I have a parts tractor with good sleeves that are 4.5 but they are for the earlier model, not the 91 series. Would the outside diameter be the same.
hectorgemme
01-11-2007 15:24:54
 Re: TD9 cylinder sleeves outer diameter. in reply to Eddie Olive, 01-11-2007 15:07:13
HI I check in my service manual and it is the same stroke 5 1/2 inchs.
