JD 450 Steering Clutch Repair
Tweeter
01-19-2007 21:36:05
I plan to repair both steering clutches in my 1966 JD 450 crawler. What parts should I replace while I have it torn apart? Are there any weak areas or parts that I should replace while in there? Where should I buy my steering clutch discs?
Lavoy
01-20-2007 12:40:39
 Re: JD 450 Steering Clutch Repair in reply to Tweeter, 01-19-2007 21:36:05
Unless you like pulling steering clutches, fix everything while you are in there. Also clean and check all linkages, springs, etc., as well. As long as it is apart, replace the pinion shaft seal, and check the bearings.
Lavoy
CH
01-20-2007 08:10:08
You should replace it all. It is ALL WEAK. You should buy your parts from ME !!
