d4 7u ??
Kelley
01-20-2007 10:39:39
Hi, got the pony motor off this morning and got the main engine out also. My question is can I get the timing gear cover off if I take the lower radiator pipe off the water pump or do I have to take the water pump off? Ser # 12xxx, thanks
Old Magnet
01-20-2007 18:01:37
 Re: d4 7u ?? in reply to Kelley, 01-20-2007 10:39:39
Hi Kelley,
You don't have to remove the water pump as part of the timing cover removal.
The big crankshaft nut is standard thread.
Kelley
01-20-2007 18:09:30
 Re: d4 7u ?? in reply to Old Magnet, 01-20-2007 18:01:37
Thankyou you've been alot of help. I took the bell housing off so I can machine it for electric start. Do you think I can get by with 12 volt or do you suggest 24 volt? Thanks again.
Old Magnet
01-20-2007 19:48:35
 Re: d4 7u ?? in reply to Kelley, 01-20-2007 18:09:30
12V works ok unless you need glow plugs for the climate your starting in then 24V is a must.
Kelley
01-20-2007 20:21:35
 Re: d4 7u ?? in reply to Old Magnet, 01-20-2007 19:48:35
Thanks again talked to a guy , says he carrys the starters for 275 without exchange plus drive.Inoticed that the pony engaged from back side of ring gear does electric have to do the same? Thanks
Old Magnet
01-21-2007 08:25:44
 Re: d4 7u ?? in reply to Kelley, 01-20-2007 20:21:35
Drive from the front works fine. Same arrangement Cat had with their direct start.
Kelley
01-20-2007 14:24:35
Another question,front crankshaft pulley. I got the reverse thread bolt out, does the big hollow nut have regular or reverse thread? thanks.
