Idler on D3C LGP
bob with idler
01-20-2007 19:02:07
Brother is rebuilding dozer under carriage, some one told him the idler bracket should fit tight on the under carriage frame. He measured and came up with a distance of 1/4 inch distance between the mounting bracket opening and the width of the under carriage after new slider metal strips mounted for the idler assemble to side on taken into consideration. ? is does the idler mounting bracket fit tight or what is the tolerance acceptable for play. It had to believe that the mounting bracket for the idler wore 1/4 inch. What ever input you can provide will be greatly appreciated.
